Thread: How to clean a SWG Cell, specifically Aqua Logic T-CELL-15
    Are there any reference videos on how to step by step, remove, verify and clean my T-CELL-15?
    I also purchased Cell Cleaner from the Pool store last year, is that just a repackaged chemical I should be getting else where for cheaper?
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    Re: How to clean a SWG Cell, specifically Aqua Logic T-CELL-
    You don't want to clean the cell unless there are visible white crusty deposits on the cell plates. If there are, you clean it with a diluted muriatic acid solution. This is all covered in the manual.
    There are a couple of YouTube videos that show the entire process, such as this one.
    Just to revisit this, I meant to clean it this year while everything was detached, there is that visible build up.
    The people that open my pool had already connected everything before I got a chance, for the life of me I can't unscrew this thing now, maybe it is a matter of water pressure, I don't know. I turned off the filter but still I can't unscrew it by hand, any suggestions?
    38,463
    Try a strap wrench or even a leather belt to get some leverage ... they should not need to be that tight.
