Thread: Do you HAVE to shock if numbers are alright?
    Aug 2009
    Spivey's Corner, NC
    10
    So we took the cover off and all my numbers when I tested were in range except the CYA was low and I needed to add salt. So I added the salt and CYA. All other numbers were good and the pool is crystal clear except for a little dirt on the bottom. So, I'm assuming I don't need to shock it.
    Thanks this is the first time opening the pool. PB closed it for us when he came back to install cover.
    True L Vinyl liner 16x24x41 3 to 8' depth, hayward sand filter + pump, goldline salt system, 25k gallon, buddy seat and diving board
    Re: Do you HAVE to shock if numbers are alright?
    There is no need to shock as long as the water looks good, CC is 0.5 or lower, and you can maintain a normal FC level.
