Results 1 to 9 of 9
Thread: Passed overnight test but...
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    ...water is still cloudy blue. Should I drop it back down to normal chlorine levels and wait? My numbers look fine (TA might be a little high), sand got changed about 2 weeks ago.
    FC: 20
    TC: 20.5
    pH: 7.8
    TA: 120
    CYA: 75
    I am ASSUMING my CYA is still 75, haven't checked it in a few days. I've added/backwashed since my last test. So do I keep shock level or let it level out? I can see about 8in down and that's it. Maybe 3 steps on my ladder?
    15' RND 48" AGP 5,300 GAL
    16" Sparco Sand filter,I got a new pump in 2010, but not sure what it is
    Successful Convert to BBB and lovin it!
    Re: Passed overnight test but...
    You should continue at shock level until either the water is clear or you have passed to overnight FC loss test.
    CYA doesn't change very quickly unless you are doing a large water replacement. I wouldn't worry about it right now.
    Mar 2011
    Sunny Central Florida
    91
    You are keeping your filter running 24/7 right? That will speed up getting rid of the cloudiness.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    You said you passed the overnite test----------then let the FC drop off and keep circulating/backwashing.
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    My filter is running 24/7, yes and yes, I passed the overnight FC loss test.
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    New numbers this morning have me a bit frustrated. The dog DID get in the pool last night. Obviously the 90 degree weather made her a bit too hot! Anyway...
    FC 11
    CC 1.5
    TC 12.5
    pH 7.5
    TA 120
    CYA 60
    Since my CC is up from .5 to 1.5 do I shock again or leave it alone?? I assume it is because my dog went for a swim. I HOPE it's not because the algae decided to come rearing its ugly head back.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You should shock it again. Anytime the CC is higher than .5 we advise you shock.
    Q: Are you covering the pool at all?
    Q: Is it possible you errored on the CC test?
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    I do not cover it, no. My cover was lost in a winter storm and I do not have the funds to replace it right now. I just did a recheck and since last post my FC has dropped to 8 and CC is at 1. I will shock again. I don't mind shocking, just want my clear pool.
    30,421
    poolmomma,
    Don't be in a rush to pass that overnight test. I wouldn't run that test again until your water looks crystal clear to you. Keep your FC at shcok level until that happens.
