Thread: Coping stage
    Coping stage
    Hi,
    I have attached a photo of my soon to be granite coping. There will be 1 inch routed out of the inner bottom of it so that the pool edge hangs over the pool an inch. L shaped.
    Is it okay that the coping hangs over the pool shell's outer edge an inch? The pavers are about 2 and 3/4inches and they will butt up to the coping.
    OR
    Does the coping absolutely have to be even with the pool shell on the outer edge?
    Thanks
    Cement 12'x30', in the neighborhood of 50 years old. Restored, 1.5"plumbing, 1hp super pump 2, Hayward swim clear cartridge filter, Summit2.5t heater,Hayward SWG t-9 cell, Nexxus Blanco lights, pentair bermuda gunite skimmer.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Coping stage
    What you have there is fine.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
