Thread: Refill Spa - Order of operations
    Jun 2007
    Atlanta, GA
    I know after I fill the spa, I have to balance the water and add chlorine. I'm just not sure of the order of operations. I know it is important because one thing will affect another. I will need to add a bit of calcium, TA, Borax, Chlorine bleach, CYA, and maybe some acid. What order should I add and when do I test to fix the PH?
    Pool: 15,000 gallon 32'x18', 3'-6' deep in-ground gunite pool, Sta-Rite 3 125 GPM 2-filter cartrige, 1.5 HP Sta-Rite pump, solar heater, Goldline SWG, Jandy controls, opaque automatic CoverStar solar pool cover, 3 waterfalls (not from spa).
    Spa: 485 gallon in-ground square acrylic over fiberglass suspended over gunite Sunset brand spa, isolated system, natural gas heater, 2-speed (4hp/11hp) main pump, 3hp booster pump, chlorine sanitized.
    To my pool store owner, nothing is more important than my pool and my money.
    Richard's PoolEquations Spreadsheet
    Mar 2007
    Coastalish 'down easter'
    Hi, IMO - sanitizer is first!! After that I'd do the pH and then the alk and ch. Add a little cya whenever you want, and by 'a little I do mean a little) You only need a small amt. of cya to take care of an indoor or covered hot tub. After you add anything, let the tub run for ~40 min and then test and re-dose as needed
    Luv& Luk
