Thread: Coping joint- Deck-o-Seal, Soudaseal, Sikaflex,Vulkem
    Which is the best polyurethane-based product out there?
    Some googling seems to turn up some dissatisfaction with Deck-o-Seal, but it may just be that it is the most-widely used product and thus has the most stories.
    Any favorites, or never-agains, out there? thanks
    24k gallon inground with 500 gallon spa, 580sqft Jandy cartridge filter, Jandy ePump 2HP variable speed pump, Jandy 1400 SWG AquaCal Heat Pump, Diamondbrite Aqua Quartz plaster
    Apr 2010
    Philadelphia, PA
    92
    Re: Coping joint- Deck-o-Seal, Soudaseal, Sikaflex,Vulkem
    I'm in for some answers as well. I need to do this in the next month or so.
    Doug
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I did mine 3 years ago with Vulkem and it has held up very well, hot summers and cold winters. It's a bit on the expensive side but it's a job I don't want to do too often.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Sep 2008
    The Woodlands, Texas, USA
    243
    Sikaflex here.... 18 months ago. Been very satisfied with its performance so far.
    I backfilled the joint with sand first and therefore used less product which saved money. Stuff was very fluid and self leveling, easy to apply, and adheres very tightly to concrete surface after setting up. Don't install on a windy day or junk will get stuck in the surface while it sets up. Does take a while to setup hard....seems like at least 24-36 hours.
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
