Thread: How do I check the drain and skimmer flow?
    Nov 2010
    South Central Kentucky
    283
    I know my skimmer flow is working properly and have been able to verify as such. Unfortunately, my floor drain valve just spins and doesn't indicate full open or closed. Is there a way I can tell if I've got it fully open or partially open or not at all?
    I can't get in the pool yet, too cold, so it will have to be a from above water solution. I was thinking maybe attach something (string, ribbon) to the end of my extension pole and hold it near the drain to see if it pulls it in?
    With that in mind, how far open should I keep the bottom drain valve? I was told that it didn't need to be fully open, but the skimmer did. How accurate is this?
    I'm mainly concerned because for one, I just don't know for sure, and I just opened and have started adding the chemicals to get my levels correct, and I want to make sure everything is circulating.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: How do I check the drain and skimmer flow?
    You could always try closing the skimmer and see if the pump starts starving. Don't do it for long, though.
