Thread: Please help not sure whats going on.....
    Hello all,
    This is the first time I have ever posted anything so if I get it wrong I am very sorry.
    This is my problem I opened my swap this week and know have crystal clear water all my levels seem to be right
    However, over the winter time I think my algae has stained my concrete to a nice brown. I have never had anything like this before. I have brushed and brushed and got a little off but not working so well. Do you guys have any Idea what could be wrong?
    Also, I have noticed that my concrete is chiping on my stairs I have owned this inground pool for over seven years and have never seen anything like this.
    Please help....
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Please help not sure whats going on.....
    Welcome to TFP!
    If the pH rose over the winter, then if you had metal ions (iron or copper) in the water then you could get metal staining. If you take some ascorbic acid, say from a Vitamin C tablet, and hold it over a stained area, then if it lightens up then it's likely to be a metal stain in which case you can follow the Pool School article on Metals in the Water and Metal Stains.
    If it doesn't fade from the ascorbic acid, then you can try putting a Trichlor puck on it to see if that makes it fade (unless it's a vinyl pool -- only do this Trichlor puck technique for a plaster or cement pool). If it fades, then it's likely to be organic and chlorine will eventually fade it.
    Thank you so much I will give that a try. You guys have beem wonderful to learn from and also wonderful to my pocket
