Thread: Bromine + ozonator: do I still need Chlorine +/or MPS?
    I have learned so much from this forum!
    Question: I recently added an ozonator to my 1995 Hot Springs spa, as I was under the impression that it would provide a constant level of oxidation and therefore allow me to run the bromine level lower. I initially load the water with NaBr per the bottle instructions.
    Previously, I had been adding MPS after every soak but now with the ozonator, do I still need to?
    From posts on this forum it seems MPS may not be the ideal shocking agent; should I use bleach instead?
    I guess I find the idea of mixing chlorine and bromine a little confusing.
    Also: do I still need the BromTabs floater now that I have an ozonator? Or will that depend on my bromine level measurements?
    Thanks in advance.
    In-ground, 13,000 gallon pool, plaster, built 2008-9.
    Pump Whisper-flow 60 gpm DE filter
    Spa: 2013 Hot Springs/salt generator
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Bromine + ozonator: do I still need Chlorine +/or MPS?
    Even though you have an ozinator it will likely not keep up with normal loading. Ozinator, bleach and MPS all perform the same function of oxidation which in turn converts NaBr (bromine bank) to Bromine sanitizer. The problem with an Ozinator is it is not as effective (fast) as bleach or MPS. You will still need to shock with bleach or MPS from time to time to get rid of med to high bather waste. It does not matter which one you use (bleach or MPS) because they both perform the same function. I prefer bleach because I already use it in my pool.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Bleach is also less expensive than MPS.
    Jan 2009
    Cupertino, CA
    1,966
    You still need the floater.
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2007
    San Rafael, CA USA
    12,082
    An ozontor does not reduce the level of sanitizer needed, but it does reduce the amount of oxidizer required after a soak to get rid of bather waste. Also, if you use the 3-step bromine method and start off with a bromide bank by adding sodium bromide to the water, then the ozonator can produce bromine on a regular basis. However, an ozonator is not usually enough by itself to handle bather waste, especially if one us using the tub every day or two. One needs to add additional oxidizer where chlorine bleach is the least expensive and can be added after a soak as needed.
    If one soaks infrequently, less than twice a week, then it is possible for the ozonator to produce enough bromine if you added a sodium bromide bank initially for the 3-step bromine system, but you'll have to measure the bromine level to be sure.
    Thanks for all the above responses.
    I will check the bromine levels and adjust the floater accordingly. It is at the lowest setting/opening now.
    Bleach is definitely less expensive!!
