Thread: Need help unplugging suction line near skimmer
    Mar 2010
    "Lamorinda" California
    52
    Have 23inHg suction on my 1.5" line.
    It seems like I've tried everything (ha ha), but have failed so far.
    Have 1.5" PVC adapted up to 2" at pump inlet.
    First, on pump inlet side I've tried:
    Water hose with two sizes of "Drain Kings" run at least 20 minutes.
    Water hose wrapped in towel run at least 20 minutes.
    1/4" & 3/16" snakes - but couldn't get past bends to main line.
    Never saw anything come out.
    At skimmer side I then tried:
    1/4 & 3/16 snake - but couldn't get to main line either because of bends or blockage.
    3/16" got the furthest. Once, previously, like 2 feet in. Today only maybe a foot.
    I'm pretty convinced the blockage is next to the skimmer as today's snaking has made the blockage significantly worse! Vacuum gage at pump now at 25inHG from 23 before today's snaking.
    This was to be my final attempt at this, so of course, today's attempt is the first time it did anything and it made it worse!
    So now I'm pretty screwed.
    I'm aware there is "art" to driving a snake, but am apparently, artless.
    Any suggestions on how I proceed?
    Thanks much.
    ~29K gal, 20'x36' rectangular, outdoor IG plaster, built in '74. Intelliflo VF; Sta-rite system 3 w/300sq ft. Liquidator 8Gal-3/8ug; Polaris 380 sweep & PB4 booster. Equip. is in shed on ground level pad.
    22,543
    Re: Need help unplugging suction line near skimmer
    Here's what I would try next. Take a wet/dry vac and hook it to the skimmer outlet. Then take the water hose wraped in a rag and pressurize the line from the other end. That may be just enough force to move it. If that doesn't work the first time swap ends. You may have to do it several times.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Another idea is to put an expandable rubber plug in the skimmer and blast water from the pad. When the rubber plug pops, the surge of water might dislodge the obstruction.
    Luv& Luk
    -Ted
    22,543
    That's a good one Ted.
    Mar 2010
    52
    Well I give up.
    I can't seem to get enough differential pressure to dislodge whatever is there and my snaking around seems to have just made it worse.
    I suspect something is really wrong in there as I don't see much reference to needing to snake a suction line so there must be something "illegal" in there like a root or a skimmer part etc.
    Anyone ever get any kind of camera in there?
    Looks like I need the skimmer replaced.
    Thanks for the suggestions.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Check your local rental center, they may have a "plumbing camera" . Also a powered snake may work for you, ask the rental folks.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
