Results 1 to 7 of 7
Thread: Design Flow Rate - Sand Filters
    Is there any problem with going under or over the design flow rate on sand filters? If it is ok to go under or over this flow rate, how high over or how far under can one go?
    16 x 38 inground pool, 20K gal, vinyl liner, 0.75 HP Hayward Superpump (SF 1.0, 115 V), Hayward Pro Serier Top Mount 24" sand filter (300lbs sand) with 62GPM design flow fate and 3.1 sq ft effective filtration area, Kreepy Krawly cleaner
    30,432
    Re: Design Flow Rate - Sand Filters
    Not a good idea to exceed the flow rate but it is a VERY good idea to stay a little under it say by about 25% or so.
    22,553
    Going over the designed flow can channel the sand and cause debris to bypass the sand. Staying under it is great the more slowly the flow through the sand bed is the more debris gets caught.
    For backwashing, you need to achieve the minimum flow rate to get the sand clean.
    Support the site
    How do I find out the minimum flow rate?
    Quote Originally Posted by jordangregory
    Backwash flow rates are typically between 75 to 100 % of the design flow rate, or between 15 and 20 GPM per square foot of sand surface area.
    Support the site
    Thank you. That was very helpful. I almost feel good about opening my pool this season!!
