Thread: Remove a patch
    Mar 2007
    Texas
    444
    Remove a patch
    Not sure what section this should be in: any way about two years ago I patched a whole on my liner and now it is starting to leak again. want to put a new patch on but want to remove the old patch first. Can you you remove a patch without tearing the liner?f so, how?Also when I put the new patch on how can I hold it in place (keep pressure on it) until it dries. It is right along the side where it starts to curve in the corner. Any help or suggestions are welcome.
    27' Round AG, 17,200 gallons, sand filter
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Remove a patch
    What I would do is re glue the old patch (the glue can be applied and will set up under water).
    Then cut another patch ~1" larger, all around, and put that one over the old patch. (advice on applying the patches is here)
    Luv& Luk
    -Ted
    Mar 2007
    Texas
    444
    Re: Remove a patch
    Thanks waste, that is what I was thinking but wanted to see if you "smarter" pool experts would know a better way.Thanks again.
    Mar 2007
    4,160
    Re: Remove a patch
    I don't know about being "smarter" ... but, thanks
    Luv& Luk
    -Ted
