Results 1 to 7 of 7
Thread: New to site
    New to site
    New member from arizona, building my own bbq island here is what im working on any comments or questions are appreciated. been looking for a site this like for a while now
    14.6K gal., 24ft, 54" above ground. 2HP, 2speed Hayward pump (4psi low, 18psi hi), 150sqft cartridge filter. 4x20 solar panel (6 psi).
    Re: New to site
    Looks like a good start. When you get done, can you come to our place?
    Pool #1 IG 24k Diamond Brite plaster with spill-over spa. Jandy Aqua Link RS One Touch with built into pool floor cleaner. Jacuzzi Magnum pump/basket feeding Hayward top mount Zeosand filter. Jacuzzi Magnum pump/basket for Spa Jets. Heat Siphon pool heat pump. Dolphin Robotic pool cleaner.
    Pool #2 IG 35K 20X40 Vinyl. Hayward top mount Zeosand filter with Pentair 3 HP IntelliFlo VS+SVRS. Chemical Free pool using Water Doctor Copper Ion Generator, PoolSkim, Polaris 9300 Sport robotic pool cleaner, Heat Siphon pool heat pump, solar blanket, Ameri-Dome 50X30 dome enclosure during Winter.
    Re: New to site
    sure, are you in arizona haha.
    Re: New to site
    can anyone help me with a question i have?? i notice people put that trex stuff under but also my ground aint level that it sits on so i just been building it with the slope and adjusting it on the slope side to make it level by making the stud longer on that side, is that ok or not the right way of doing it??? people help
    Re: New to site
    There are tradeoffs. The best thing to do is to use leveling feet to level the frame and then make everything on the frame square. That makes everything easier to measure and the panels to cover the frame easier to cut. The counter point is that if the ground isn't level it will look nicer if the panels are a uniform height off the ground, ie if the bottom of the panels are not level. As long as you are careful to keep the counter level and the verticals vertical I don't suppose it makes that much difference.
    Sep 2009
    Brentwood, CA
    21
    Re: New to site
    Definitely put trex or some other material under your frame if you are going directly on concrete. I made the same mistake, I framed mine and realized the importance of the barrier after. I ended up buying 1/2" trex plank and slipping it under the frame, then I anchored the framing and the trex to the concrete. When I finished I also installed the left over trex board across the base so the entire Que has a nice clean floor instead of concrete. It gave the inside a nice finish.
    Good luck!
    Ingroud plaster pool, 13000 gallons, with SWG
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: New to site
    Welcome to TFP
