Thread: Compatible cell for 2005 Aqua Rite control panel
    Apr 2011
    Davis, California
    3
    My 6-year old T-Cell-15 is dead. I ordered a T-Cell-3 on the internet. Although the web site indicted it would work with my system, the instructions that came with the cell indicate that it is not compatible with systems older than 2009 or with software versions lower than 1.5. Is my system so old that I need to replace the control panel too? Or should I order a newer PCB for my control panel? My panel software version is AL 1.33. Or is there an available cell that will work with what I have?
    9,000 gal IG fiberglass; Jandy 1 HP pump PHP1.0; Jandy CJ200 100 GPM cartridge filter; Vantage in-floor circulation system with Paramount water valve; 5 Hi-Tec 4'X12' solar collectors with Heliotrope HM-4000D controller; Aqua Rite SWG with T-Cell-15.
    Oct 2010
    Georgia
    317
    Re: Compatible cell for 2005 Aqua Rite control panel
    You need to replace the cell with the same t-cell-15. T-cell-15 cells have a 3 year warranty.
    A less expensive cell that will also work is the GLX-cell-15 which only has a 1 year warranty.
    The t-cell-3 and t-cell-9 cells are low output cells and are only compatible with main boards with software version 1.5.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
