Thread: Tanning Shelf LED Lights
    Apr 2011
    Oklahoma
    37
    I've read that LED lights usually need 18 inches of water, Min. I'm building a 10/6 tanning ledge and would like to put an LED light on it as most tanning shelves never get lit by the pool light because they sit much higher than the pool light.
    Can I put a small LED light in 7 inches of water?
    Does anyone have suggestions of a shallow LED light?
    Thanks for your help.
    34 x 19 salt water free form. 7.5" inside diameter raised spa. 24" raised beam in back. 3 moss rock waterfalls off raised beam and moss rock waterfall out of the spa. (2) Intelliflo VF pumps, 420 Cartridge Filter, 400 BTU Pentair low nox heater. 2.5" suction and 2" returns throughout.
    Mar 2011
    Scottsdale, AZ
    406
    Re: Tanning Shelf LED Lights
    You can use the Nexxus Savi Melody, or Savi Note.
    They can be in as little as 4" of water.
    The other way to do it would be with fiber optic lights, which can go just about anywhere.
