Thread: When should I run my pump?
    Jul 2010
    Pt. Arthur, TX
    174
    Let's say I've decided on a 12 hour cycle, should I run it to take advantage of the night time hours, the daytime (sunlight) hours, or a mixture?
    Custom Cloud shaped 19'x35' - Raised Spa 6' diameter
    Rainbow 320 Inline Chlorinator - Paramount Clear O3 Ozone Generator
    Hayward C4025 Cartridge Filter (Hayward CX880XRE) - Hayward Tristar 2 speed pump
    Hayward H400Fdn Heater, Hayward GVA-24 (valve actuators)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: When should I run my pump?
    Noon to midnight and see how it works out for ya'. Just got in some more tripper switches for my timer to play with and split it up. Don't think I ran mine more than 8 hours a day last year till it got REALLY hot.
    Mar 2009
    Charlotte, NC
    539
    2 x 6hr cycles, as far apart as possible, one of those cycles to start 1 hr prior to testing.
    Be sure you need 12 hrs, seem a bit much? A well balance pool needs 1 turnover per 24 hrs I think ( a few circumstances will require more & sometime you want to err on the safe side so a tad longer; also water temp, debris, sunlight hrs etc all affects this). How long does 1 turnover take w your equipment? The pros here can help you estimate that. Ask away
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
