Thread: Could this be my leak?!
    "normal" pipe install
    I'm digging today to try and find my skimmer side leak (finger's crossed). Here's what I've found so far:
    [attachment=1:2o5foldr]plumbing.jpg[/attachment:2o5foldr]
    [attachment=0:2o5foldr]plumbing 2.jpg[/attachment:2o5foldr]
    Is that normal to place bricks on top of the lines and then cover with dirt?
    Wanted to know if I should replace them when I refill the holes - after I find the leak - which I am determined to find today!
    16K Gal in-ground Vinyl, Sand Dollar sand filter, Haywood pump
    Nov 2010
    152
    Re: "normal" pipe install
    Not really "normal", but may have been done to protect the pipes from being hit while digging... They aren't necessary, assuming you're not going to be doing excavation in the area for sprinklers, etc.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
    Could I have possibly gotten so lucky??
    I can see a hairline crack - a tree root is forming a "v" and seems to have maybe squished it and created a crack - is that possible?[attachment=0:1tmmp9y5]crack.jpg[/attachment:1tmmp9y5]
    Mar 2011
    Lower Bucks County,PA
    65
    Re: Could this be my leak?!
    The only way to tell is to run system now that you have it exposed. By the look of your back fill , could of been cracked when covered or sanwiched between fill and growth of root.
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
