Results 1 to 16 of 16
Thread: how can I remove debris from here?
    What is this piece called? Why is the debris there? How can I remove it? What should I know before I remove it? What problem does it make? If I don't clean it what will happen?
    Thank you
    13,000 gallons
    Cartridge
    IG
    Fiberglass
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: how can I remove debris from here?
    If that's a strainer basket just before the pump.....unscrew the lid and empty/clean the strainer.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yup, there should be a handle or something to grab a hold of and unscrew the lid.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Make sure you turn the pump off first...
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Jun 2008
    Port Neches, Tx.
    144
    You need to isolate it also, block the valves upstream and downstream.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    1 1/2 hp pump, sand filter
    Quote Originally Posted by newnick
    That depends on the height of the pump relative to the hight of the water in the pool. With the pump above the pool there is no need to close valves, but with the pump below water level it is crucial to close valves.
    Jun 2008
    Port Neches, Tx.
    144
    Good point.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    I removed the lock ring. I cleaned the basket. I put the lock ring and basket on. I turned on the pump. Air does not blow into pool. What did I do? Thank you
    13,000 gallons
    Cartridge
    IG
    Fiberglass
    Jan 2010
    Randleman,NC
    620
    Did you turn the water flow valve's back on?????
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by edwardscissorhands
    Air doesn't blow in the pool?
    The jets don't work.
    13,000 gallons
    Cartridge
    IG
    Fiberglass
    Jun 2010
    Glendale, CA
    513
    Did you leave the pump on for a little while? When you open the basket the pump looses prime - so it needs to reprime (fill with water) before it will work.
    If it is something more exotic than that - post a pic of all your equipment so we can better see your situation.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    OK. A neighbor turned a valve and fixed my problem. Thank you.
    I did fill with water, but it didn't take a minute. I never got it to fill up but filled it up for a while.
    So, now my filter tank is half full with water. What does this mean?
    Also my pump I felt was too hot to touch so I turned the pump off immediately.
    13,000 gallons
    Cartridge
    IG
    Fiberglass
    Apr 2011
    Marietta, GA
    9
    Could it be you ran it for awhile with the valve closed, and the pump worked so hard it superheated? Leave it off for an hour, check the temp on it before you turn it back on. If it is cool, fire the pump back up and check it every 5-10 minutes or so. If it continues to superheat and the jets are flowing, it could mean the brushes in the pump motor are going. If it is flowing correctly, I doubt there is an obstruction in the pipes.
    Guessing 27,000g
    18'x40'x8' IG Vynil lined pool
    Sand filtered
    1-1/2 hp pump
    swcg system
    22,553
    Wiseguyfish -- everything you said is correct except the part about the motor brushes. Pool pumps use squirrel cage motors and they don't have brushes.
    Apr 2011
    Marietta, GA
    9
    Thank you sir. I stand corrected.
    Guessing 27,000g
    Sand filtered
    1-1/2 hp pump
    swcg system
