Thread: liner reoval to level bottom
    hi all
    i have a 1 yr old above ground pool
    the pool company here in ontario, canada used peat moss for the bottom instead of sand
    well after the water warmed up last august i finally got to get in
    bottom was very soft and you need alterain feet to walk on it
    so after months of complaining they are going to remove liner an level out the bottom
    my worry is that the liner will not be ok after they re install
    thanks
    gregc
    18 ft agp newbie
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: liner reoval to level bottom
    If they re-install the liner the same day it should be o.k. If they damage the liner insist they repair or replace it, depending on how much damage is done.
    Love TFP? Become a
    TFP Supporter!
    thx
