Results 1 to 8 of 8
Thread: Salt level accuracy: New SWG or strips?
    Aug 2010
    MA
    173
    New IG pool installed last fall(see sig for details). PB opened the pool and started up the system for the 1st time this week. Salt was added, but not sure as to how much. After letting the water circulate for a couple days I used the salt test strips I ordered with my TF-100 and got a reading of 3950ppm. My SWG is reading 2800. Display says chlorinator is off due to low temp. Water = 48 degrees. PB says the strips are wildly inaccurate and I should trust the SWG reading. So depending on which reading I go with, I am either high or low
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Salt level accuracy: New SWG or strips?
    Cell won't produce at that temp.
    You can reset the instant salt in the at the panel,but I would wait until water warms up.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    JesseJames's Avatar
    Sep 2009
    Florida
    64
    I use the Taylor Salt Water Test Kit K-1766.
    13K Gal., Plaster, SWG, Intellichlor IC 20, Sta-Rite 1 HP Pump, Sta-Rite PLM 300 Filter, Pentair LED, Solar, Screened Enclosure, Great White, TF-100
    Dec 2009
    Central Massachusetts
    2,690
    The water is too cold. Dont worry too much about it. And yes, i've never had luck with the strips. They always read high, at least for me. Once the water warms up, the salt reading on the panel will go up; it's temp dependent.
    Once the water hits the upper 60's it will work itself out.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Trust the Taylor kit.
    Aug 2010
    MA
    173
    Thanks for the replies.
    I realize the temp of the water is too low for unit to generate chlorine, but do I need to add more salt? Sounds like I should wait untill the water temp rises as the salt concentration will rise as well.
    Also, its strange that unit will only display the salt level as it scrolls through its current readings(air/water temp, date/time, chlorinator %age etc) when I put the pump on high speed. Will the cell will be able to produce chlorine on low speed?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Just wait! Once it warms up, if it isn't generating then post some new readings.
    Unless the generator is complaining about low flow on low speed, it will generate. What does it display on low speed?
    Aug 2010
    MA
    173
    Quote Originally Posted by Melt In The Sun
    Everything but the salt reading. air/water temp, date/time, chlorinator percentage setting and chlorinator off - low temp
