Thread: filling the spa ..
    filling the spa ..
    PLEASE SOMEONE HELP!!! i have a easy touch pool & spa..going on 5 years now..
    i need some one to tell me how the Heck to get the spa to fill up!!????
    i got a new pump because it was old..and it started to smoke when i would turn on the power.
    i have tried everything..even turned on the jjets to fill it up..
    HELP!!! user guide does not have a chapter on filling & drain the spa...
    thanks
    tony
    21,500-gallon tiled gunite with 65' infinity edge. Two Intelliflo VS pumps, one for trough one on pool. Pentair 520 cartridge filter on main circuit ,Pentair 200 cartridge filter on edge circuit. Easytouch, Intellichlor 60, Intellichem with external acid pump, Intellibrite 5g lights.
    Testing: Taylor K2006 (with FAS/DPD). Taylor K1766 salt.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: filling the spa ..
    Garden hose?
    umm... i know how to fill the spa with a hose..smart guy..WHAT im looking for is how it fill its self..I KOWN A HOSE WILL FILL IT ..but there is a way AUTOMATIC to do it ...
    thanks for nothing
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You need to direct the returns to the spa rather than the pool. There should be a valve controlling this. A picture of your equipment would help, if you can't find it.
