Thread: Need help with my battle
    Jun 2010
    Waco, Texas
    66
    Hi
    Had a weird day yesterday. Have green pool so gathered my bleach and test kit- tf-100 and started to get ready for the fight. My cya seemed to be 50 and my tc was 4 I decided to shock and tried to get it to 20. An hour later. When I added the r-870 I got a slight tinge of pink and after I swirled it it was clear...clear? So I panicked and decided to add enough to bring it again to 20 and an hour later. The test was the same but this time I added a drop of the r-871 (curiosity) and it started to turn pink..what the heck. I sent hubby to pool store this am for correct readings....see below
    Test Name¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* ¬* Acceptable Range¬*¬*¬*¬*¬*¬* Value
    Free Available Chlorine¬*¬* ¬*¬*¬*¬*¬*¬* 1 to 4 ppm¬* ¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* ¬*6.03¬* high
    Total Chlorine¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 1 to 4 ppm¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 6.03¬* high
    Combined Chlorine¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* <0.2ppm¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 0¬* OK
    Total Alkalinity¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 80 to 120 ppm¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 221¬* high
    pH level¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬ *¬*¬*¬*¬*¬* 7.2 to 7.6¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 7.9¬* high
    Calcium Hardness¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 200 to 500 ppm¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 26 low
    Cyanuric Acid¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 20 to 50 ppm¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 19¬* low
    Copper was 0
    Iron was 0
    Total Dissolved Solids¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 0 to 2000 ppm¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* 0 OK
    Saturated Index¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* -0.3 to 0.3 ppm¬*¬*¬*¬*¬*¬*¬*¬*¬*¬*¬* -0.3¬* OK
    So I guess I am asking ...could my r-870 have gone bad over the winter? Was kept in a drawer away from water, heat, and cold
    Pool store was telling my DH to flock and brush vacuum, back wash blah blah
    I don't want to begin my TFP method of algae fighting unless I know I have my test kit working well
    Thanks in advance
    Becca
    Kawfy
    AGP 16x32x52 Cornelius, guesstimate of 15400 gal. Dished out in center to 5 ft , Counter sunk 1ft 10"
    Jacuzzi 1.5 hp pump, 300 lb sand filter
    Full hot sun in Heart of Texas
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Need help with my battle
    Add more powder! With high FC you sometimes need more.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Ditto..those pool store results look real suspect.
    Jun 2010
    Waco, Texas
    66
    Ok. Spoke with Duraleigh, found out that sometimes I need to use more than 1 scoop of r-870 and that actually I dosed again off the assumption I had zero fc when actually I had quite bit. The pool store test results were waaaay off. I retested the water and found my fc to be at 26 and I am going with my test result of 50 for cya. Thankfully I had 50 vs 19 cya to buffer my error on bleach dosing. This is my 2nd season so I am still learning and still so very thankful for everyone at TFP! I even got a proper lesson on how to use my filter since the pool installer assumed I knew...thank you Duraleigh!
    Kawfy
    Jun 2010
    Waco, Texas
    66
    Melt in the Sun
    I had no idea you could/should add more powder. If the directions say ONE scoop...that is what I do .....in any case...lesson learned and I am feeling much more confident with MY results vs the pool store.
    Kawfy
