Results 1 to 8 of 8
Thread: Can you tell me what the tap in the attached photo is for?
    Oct 2010
    Temecula, CA
    122
    please
    Temecula, CA
    16X32 (approx) 20k gal, DE filter, IG, plaster/pebble with diving board & slide
    Whisperflo pump; Pentair SMBW 4000 Series filter... that's all I know! Still learning....
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Can you tell me what the tap in the attached photo is fo
    I'm assuming you're talking about the faucet. It is used to pressure test your pipes.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Oct 2010
    Temecula, CA
    122
    Sorry DH is Irish and I guess he rubbed off on me. I do mean the faucet.
    Temecula, CA
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You can also use it to slowly drain your pool.
    Dec 2010
    San Diego, CA
    1,137
    Or quickly depending how much you open it.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Oct 2010
    Temecula, CA
    122
    Sorry apparently I asked the question wrong. We started the pump that we recently moved and we were not able to draw water up the pipe to the pump at all - can we use the faucet to help bring the water up to the pump, then turn it off so we don't actually start draining the pool? I hope that makes sense.
    Thx
    Temecula, CA
    Oct 2010
    Temecula, CA
    122
    Nevermind, we got it working now. Got a bit of work to do now to clean up the water.
    Temecula, CA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    That hose bib will come in very handy should you need to drain water out for any reason. The flow won't be quite as extreme as the backflush port. If Calcium gets scary high, which it likely will in Temecula, you can use it to water the lawn, then refill using fresh water.
