Page 4 of 4 FirstFirst 1234
Results 61 to 70 of 70
Thread: vinyl liner pool build in Ontario, Canada NEW PICTURES
  1. Back To Top    #61
    Aug 2011
    Mechanicsburg, PA
    40
    Re: vinyl liner pool build in Ontario, Canada NEW PICTURES
    What is the size of the pool in gallons?
    I am in process of building about the same size double roman (20x46) and was suggested to use IC60 cell.
    IG double roman vinyl 40x20. 35000 gal. 9' deep. Diving board.Pentair 400HD gas heater, ItelliFlow Variable Flow pump, 520 cartridge filter, two pentair G5 lights, IC60 SWG cell.
    Photo album: http://slava.no-ip.org/~poolpic/photo
  2. Back To Top    #62
    Sarnia, Ontario Canada
    162
    my math comes out to 33000 gallons. the pool proper is 20x43, with the stairs making it a few inchs shy of 47' long. Haunch to Haunch, the pool is 38', then the roman ends add 2.5' each.
    I guess my math was wrong. i looked at the dig sheet and it says it is a little less than 27000gal, then add a little for the swimout and stairs...
    20x47' double roman vinyl liner pool. Pentair EasyTouch 8PSC-IC40, 011018 Pentair IntelliFlo, Pentair Clean & Clear Plus Filter CCP420, Pentair 120V IntelliBrite LED, Cleardeck indeck solar reel, 530 sq' solar system Polaris 9300xi robot, Interfab Turbotwister slide, S.R. Smith T7 diving board, deck jets vinyl-liner-pool-build-in-ontario-canada-new-pictures-t30213.html
  3. Back To Top    #63
    I really liked watching this build. I am in the process of a similar project. I was curious if the one LED light was enough? Any picks with the light on? And when you back filled what did you do to compact the soil before laying the concrete? I am decided on weather I build the pool, back fill, and then wait until spring to do liner and concrete or fill it up and winterize before we get a freeze. Thanks
    Under construction DIY 20x40 vinyl liner steel wall pool, Pentair 2hp wisperflo, Pentair tr100 sand filter, Pentair Minimax 400k heater, diving board, 8 foot sit n step, xtream waterslide, 1700 concrete deck, one amazing wife, 4 children and two German shepherds.
  4. Back To Top    #64
    162
    Sorry so late... No picks with the lights on... Since they have not yet been on. Soon though!
    I used a walk behind plate tamper slightly moistening before. I also used a rod right up against the pool walls to make sure there were no voids. Best to use clear gravel if you can... Packs best, no settling. Next is sand then loam. Last would be clay. Avoid using it.
    Good luck. I'll post more
    Pics soon
  5. Back To Top    #65
    162
    finishing the odds and ends: fence, grading, sod, tying in solar, automation system, diving board... (ok, i have lots to do still!)
    i lost the battle on growing my own grass. 15400sf of sod was delivered and installed (pool party for my sodding friends TBA). That's me on the Kubota doing some final grading. I scored a great deal on an oversized safety cover. where it overlaps more than recommended i have made wear strips.
  6. Back To Top    #66
    162
    and a few more. these are in reverse order. i pulled the cover off...went to TFP...read the pool opening sticky. followed directions. last picture is saturday night, middle is sunday morning and first one is monday morning. approx 7 182oz bottles of clorox, 24/7 filtering and Robbie the Robot in action...
  7. Back To Top    #67
    162
    last ones for now. i used "oz posts" to anchor the fence posts in the ground. where the fence goes over concrete, I had the brackets made. i used stainless washers under the plate so it is not in direct contact with the concrete. 3 3/4" redheads hold them in place.
  8. Back To Top    #68
    I would appreciate your feedback for the Cleardeck system.
    We're considering adding it to our build, as it obviously keeps the cover hidden and out of sight. It sure is costly upfront!
    Thanks! - Beautiful build BTW!
    Assembly stage of:
    18x36 DIY IG - SWG - Pro-Logic P4 - Hayward Universal 12V LED - ClearDeck Inground Solar Cover System - 2 Skimmers, 5 Returns + 2 Step Returns - 400BTU Hayward NG Heater - 1.5HP Hayward TriStar 2sp Pump - 30" Hayward Sand Filter - 280sq/ft Enersol Solar Heating - Solid Safety Cover with mesh drains - 30mil TideWater Liner - - TF100 - 20'x30' Pool House/Dog House :)
    New Lowell, Ontario, Canada.
  9. Back To Top    #69
    162
    The clear deck is one of my favorite
    Add ons. It works well, looks good, saves on chemicals, keeps
    **** out of pool, keeps
    Heat in, so less solar pump time required (my electricity is time of use billing. Ie expensive during the day)
    So bottom line. I use it, because it works as advertised.
    My only comment is that it will work best on pools with a flat end, not irregular shapes since the shape of the coping the solar cover contacts while it is being rolled up can cause the cover to wrinkle a bit. We a double roman. A single roman would have worked a bit better. I'll take a picture of my solution.
  10. Back To Top    #70
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    Quote Originally Posted by tatertot09 View Post
    Your build is looking great! I responded to your question of the Umbrellas and posted a link with it! It would look beautiful around your pool!!!!
    I know this is old, but what did you post? Sounds intriguing.
    New Build started April 2015, 20x30x40 Lagoon Style Vinyl (indigo marble/blue granite), 27,500 GAL, IG, 839 square feet, 9' tanning ledge/baja shelf, 9' radial bench, 8' classic Waterfall, 3'6" to 8'Depth, Sand, Pentair 2 speed Superflow 1 1/2 HP, SWS, 2 Pentair LED Intelibright 5 G lights, Pentair Legend Platinum II pool cleaner, 2 skimmers, 3 returns. 1080 square feet of Silver Slate stamped concrete.
