Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 70
Thread: vinyl liner pool build in Ontario, Canada NEW PICTURES
  1. Back To Top    #21
    Sarnia, Ontario Canada
    162
    Re: vinyl liner pool build in Ontario, Canada
    2nd set
    20x47' double roman vinyl liner pool. Pentair EasyTouch 8PSC-IC40, 011018 Pentair IntelliFlo, Pentair Clean & Clear Plus Filter CCP420, Pentair 120V IntelliBrite LED, Cleardeck indeck solar reel, 530 sq' solar system Polaris 9300xi robot, Interfab Turbotwister slide, S.R. Smith T7 diving board, deck jets vinyl-liner-pool-build-in-ontario-canada-new-pictures-t30213.html
  2. Back To Top    #22
    162
    3rd set
  3. Back To Top    #23
    162
    4th set
  4. Back To Top    #24
    162
    last set...for now
  5. Back To Top    #25
    162
    Re: vinyl liner pool build in Ontario, Canada NEW PICTURES
    finalizing equipment
    upgraded to the 8 function easytouch with intellichlor
    added a t7 diving board with led and waterfall
  6. Back To Top    #26
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Looking really good!
  7. Back To Top    #27
    Apr 2009
    Burlington, ON, Canada
    344
    At first I thought, that's the biggest, deepest, most rectangular pool I've seen. Then I wondered why the walls were styrofoam, then I saw the pic on page 2 and realized it's a.......house? For the inlaws?
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
  8. Back To Top    #28
    162
    Quote Originally Posted by rcy
    that's what the neighboUrs are worried about...
    its a long story...i didn't plan on putting a basement...it just kinda happened.
    and the training course i took for those blocks had 2 pool builders in it. they are using these to form and insulate pools now. you can get curved forms. you can do it concrete, or drop a liner. i considered it, but then decided against it and ordered a regular pool kit.
  9. Back To Top    #29
    162
    roofing today. shingle are all on the backside... deck armor down in the front ready for shingles...tomorrow
  10. Back To Top    #30
    Apr 2009
    344
    Quote Originally Posted by armstrr
    Interesting...I wonder how much heat is lost through the pool walls in a normal steel wall vinyl pool, or even a concrete pool. Would the styrofoam help with that? When it comes to dropping a liner, wouldn't the styrofoam be too soft (like easily dented)?
  11. Back To Top    #31
    You mean the pool is not going in the house
    I too thought the styrofoam was for the pool,....then I thought what a neat indoor pool.
    Nice work, can't wait to see more.
    John.
    "Experience is what you get, just after you needed it."
    Owner DIY build, steel/liner kit, 18x36 Deer Creek, sport depth, approx 17,500 gal,
    Aqua Plus SWG, 1 1/2 hp, 2 speed, 300# sand filter and twin Color logic 4.0s, MX-8 Cleaner.
    My DIY Pool Build
  12. Back To Top    #32
    162
    It is 2 5/8" foam on either side of the concrete. I believe it ends up being an r23 wall. Just imaging pouring hot coffee in a concrete or steel cup. I wouldn't pick it up... Of course the greater the thermal gradient, the more effect the styrofoam will have. I think if you want to heat a pool in the shoulder seasons, it would be much less costly if it it were insulated by these forms. Of course you would keep a lid on the coffee, same as it is important to use a solar cover. Evaporation is the enemy.
    The foam is actually very sturdy. It takes a lot of force to dent it. Above grade it would be a lot easier then underwater... I suppose I'd you purposely kneed it... But remember, it is backed by concrete, so you can only compress it so far.
  13. Back To Top    #33
    162
    7 ridge cap shingles shy of completion!
  14. Back To Top    #34
    162
    build began monday july 24, 8am
  15. Back To Top    #35
    162
    panels were installed as pool dug. a mini was used, so he threw behind him and a skid steer moved the earth (well....sand). you can see from how high my shop on the right is, we hit the water table, so the last picture was no great shock
  16. Back To Top    #36
    162
    walls going up
  17. Back To Top    #37
    162
    hole was dug and walls bolted up by 330...i could not have done that myself. at this point i am happy i hired it out!!!
  18. Back To Top    #38
    162
    leveling, shimming, and my high water table....
  19. Back To Top    #39
    162
    more pics
  20. Back To Top    #40
    162
    and more pics. leveling, concrete. extra braces installed around swimout, inwall ladder and stairs.
