Results 1 to 14 of 14
Thread: Pool guys CAULKED my Jandy Ray Vac Energy Filter in place!!
    Oct 2010
    Fulton, MD
    24
    Arrgggh! Not even one full season with the pool and I'm already running out of pool "professionals" in our area that I haven't fired!
    The latest is this -- I went to try and unscrew (for cleaning) the clear plastic bowl that holds the "Energy Filter" for the pool's Jandy Ray Vac system. I couldn't budge it, so (thinking it was my lack of strength), when my husband got home I asked him to have a go at it. He discovers that someone caulked the bowl in place, right at the joint where it should unscrew! It has to have been the guys from the pool company we hired to close the pool last fall and open it last week (not sure if it happened at closing or opening; would this part normally be taken off and stored for winter, or left in place?). I already know that the opening team didn't have any familiarity with the Jandy Ray Vac because they hadn't set the pressure correctly (so it wasn't running right) and I called the company about it; they acknowledged that the guy who was here, though he was "very experienced", was not familiar with Ray Vac since they are not very common.
    My husband tried to scrape off what caulk he could, but still couldn't get the filter unscrewed. We can't run the Ray Vac anymore til it's clean -- it all gunked up with worms and other lovely things so there's not sufficient pressure to run the unit properly.
    Any suggestions?? What's involved if it can't be unscrewed and the whole filter section on the pipe has to be replaced? Do I let the pool company send someone else out if they say they have someone who can fix it??
    Here's a link to the Jandy Ray Vac owners manual. A diagram of the Energy Filter is in Section 6.
    http://www.jandy-downloads.com/pdfs/H05550A.pdf
    14,000 gal. in-ground white plaster, 24" Crystal Flo Sand Filter, automatic cleaner, Laars Lite 2 400K BTU Heater
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Pool guys CAULKED my Jandy Ray Vac Energy Filter in plac
    Did they leave you a detailed list of what they did when they closed or opened the pool? Call the pool company back and let them know what happened. They should replace the part if they can't get it open.
    Love TFP? Become a
    TFP Supporter!
    That is crazy. I can't imagine what they were thinking.
    You might be able to fix it by scraping off all the caulk you can get to and then trying to open it up with a strap wrench, or it might be ruined. Replacing it with a new one is easy enough for anyone with PVC experience, aside from the obvious expense.
    1st - bad pool boy. If one of my guys did something like that, they'd be gone.
    2nd - these things leak... a LOT. Probably why someone with no brains tried to "fix" the leak with caulk... The "secret" to preventing them from leaking is to NOT tighten it all the way. When you put them on, tighten it until it won't turn anymore... then back it off ~1/8th of a turn. Also make sure the o-ring is clean.
    3rd - Cut out the JEF. JMHO. Find piping on the other side of the filter (filtered water side) and put in a 3-way valve there, and run that to the ray-vac. That way, 1/2 your water isn't going through the system un-filtered... which is oxymoronic because they call it an energy saving filter... How exactly is it saving money if it's not letting 1/2 of the water be filtered by the system? What a waste! Now you need longer pump run-times to get the same effective filtration.
    4th - I hate RayVacs... just a personal bias. They always drop their crud when you try to empty them - even when you're careful. I've also seen the Rayvac scar up plaster because they're running too fast, are hard plastic, and shoot through the pool like a bullet. Throw that thing away and get The Pool Cleaner pressure-side.
    - Jeff
    [edit - to Jason's point... for these things, strap-wrench's ROCK. Lowe's has a great strap-wrench. Love mine.]
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    Oct 2010
    Fulton, MD
    24
    You guys are awesome. Thank you.
    Already tried a strap wrench, although I'll have to check out the one at Lowe's. Maybe it's bigger. The only "list" they left at opening was a generic checklist with "Good" checked in every case. I'm going to call the company in the morning and see what they have to say for themselves. Should be good for a couple of laughs. Taekwondodo, any chance you're considering opening a store on the East coast? You would eat up the competition.
    Feb 2010
    Inland Empire/SoCal
    462
    If you need a new one I'll send you one for free. I have 3 of them lying around. TFP special - PM me.
    OB Pool - 45K Gal. 64'x25' free-form IG - 35'x18" raised bond beam - Swim up bar w/ 5 stools - 14'x8 ' sunken patio/grill area w/ icemaker, fridge, SS cabinets, sink, granite counters, dual head grill - 14' spa w/12 venturi jets - 2 fire bowls - 1 firepit - Indeck drink cooler - 3 fiberlit waterfalls - 14' sun shelf with 2 fiberlit bubblers - 25 x fiberlit star floor fixtures - 5 Pentair Intelliflow 3HP pumps - Tiger Shark QC Cleaner - 4 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Intellichlor IC40 alt cells - Intellitouch i9 w/ i10x expansion - Pentair IS10 spa side remote - MobileTouch2 - 4 Valve Actuators - Silencer Blower - Pentair 520 Cartridge Filter - 2 fiberlit laminars - 4 Fiberstar Illuminators - Perimeter fiberlit bar counter and spa - 2 Bermuda Skimmers - 8 Returns - Hydrazzo custom color plaster - Natural quartz ledging - Glass Mosaic Tile - 2000 sq ft paver deck w/ double banded poured coping - Interfab G-Force Pool slide.
    South Central NJ
    3,192
    If you have a long screw driver, you can improve your available twisting torque to get the bowl off. The bottom of the clear bowl has nubs on it for just this purpose. Catch two with the blade. Square shafted screwdrivers work best.
    Once you get it off, replace the o-ring and lube it. Clean the threads!
    Scott
    Owner of - PoolGuyNJ LLC
    Just gonna say it one more time... "SAWZALL!!!"
    Oct 2010
    Fulton, MD
    24
    Spillmar, wow, thanks, how generous! I will definitely PM you if we determine we need a new one.
    PoolGuyNJ, thanks, actually we already tried the screwdriver trick, it didn't work, but maybe we need to try with a longer square-shafted one.
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by taekwondodo
    Sawzall solves all!!!
    My filter gets the sawzall next week. I"ll have to take pictures
    Oct 2010
    Fulton, MD
    24
    Update:
    I called the pool company and they said that they actually sometimes caulk the things ON PURPOSE, since they tend to leak. I said, okay, but how do I get it off? The answer was it's supposed to be done so you can still get it off. Whatever...anyway the owner of the company came out personally and got it unstuck (he must have had a stronger/bigger strap wrench) and lubed it up. Now I'm able to get it on and off to clean (have done twice since then). I give the company credit for making it right -- and if I use them again I'll be sure to request the "A" team.
    Taekwondodo, the advice about not putting it on too tight was right on -- now know how to put it back on so it doesn't leak.
    Once again, the collective experience of TFP saves the day!
    Glad to be of help! But, I still say cut it out and put the low-pressure fitting on the south-side of the filter
    Just more efficient, and no J.E.F. to clog (I've seen them literally crushed when they're not serviced enough) or water bypassing the filter.
    Sep 2013
    East Bay, SF Bay Area, California
    24
    Old topic but helped me understand what that small filter is all about in my pool. Just wanted to add a note. thank you.
    Go Spa 742 | 310 Gal | Ozone | Lucite Cast Acryllic | 220v | Installed Aug 2013
    Grilling | Cooking | Wine | Coffee Home Roaster | Frozen Concoctions
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    I used to have one of these cleaners. My builder installed the filter backwards so the water entered from the wrong side. This meant the dirt collected inside the mesh filter cartridge instead of on the outside of it making it ridiculously difficult to clean. Stupid. Only way to fix it would have been to cut it out and replace the whole assembly so I never bothered - just lived with it. That said, mine never leaked so I never had to caulk it.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
