Thread: Burned out second sump pump - on second use this time...
    Draining a pool - Utilitech 1/2HP 4,000GPH sump pump. Dang thing just stopped pumping - motor was still turning, water was at a trickle (with NO head, maybe 1')...
    Any idea why TWO of these didn't last more than a couple of pools each (this is the second one that failed after just a couple of uses)? Any recc's on a GOOD sump pump? Have a partial D&F and need to get a new pump - don't want to buy a(nother) piece of junk...
    Thanks.
    - Jeff
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    Mar 2011
    Scottsdale, AZ
    406
    Re: Burned out second sump pump - on second use this time...
    I always use the Sta-rite sump pumps. I prefer their cast iron series. They are pretty bullet proof. We use them daily to drain, and acid wash pools, and they keep on ticking.
    http://www.pentairpool.com/pdfs/Subm...SumpPumpIG.pdf
