Thread: Temporary alternative to tf100
    Mar 2011
    Lower Bucks County,PA
    65
    After 12 years, replaced liner, skimmer and some assc. Want to go BBB with new start up, but for the next month funsrlow. $68 for the kit don't fit and will be finished filling this weekend. Any suggestion's on a kit to get by with till i can order one. Don't want thing's to get out of control. Thanks.
    !2X24X52" oval
    SE PA
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    Re: Temporary alternative to tf100
    There is an HTH 6 way drop based kit from WalMart that is very reasonably priced. You only get two or three CYA tests and the only chlorine test is OTO (TC from 0-5) but otherwise it is fairly good. Don't get it mixed up with the 6 way test strips, which are not nearly as good.
    Mar 2011
    65
    Will check it out Jason, Thank You kindly!
    Hi-Flo 2sp 1hp pump
