Results 1 to 8 of 8
Thread: Probably a silly question....
    Apr 2011
    Graham, TX
    5
    I am a relative pool noob. In digging around all the stuff that the previous homeowner left us for the pool I came across something that looks like a huge cover made out of blue bubble wrap. What is it and how/when do I need/use it?
    27K vinyl, FPS 48 filter, Polaris 280
    Feb 2011
    Sicklerville, NJ
    80
    Re: Probably a silly question....
    It's a Solar Cover. You put it on every night after swimming to hold down evaporation and keep the temperature up.
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    Apr 2011
    Graham, TX
    5
    Wow...learn something new everyday. Is there some way to keep it from blowing off? Of course, around here in the summertime I can't imagine having to keep heat in the pool.....
    If it fits well and is flat against the water it won't usually blow off. If you do have problems with wind you can weight it down with something like water jugs that won't damage the pool.
    Apr 2011
    Graham, TX
    5
    Cool. I guess I will have to drag it out this weekend and unroll it to check it out. Thanks!
    Jan 2011
    Riverside, CA
    352
    Here, I'll answer your next question before you ask it:
    Bubble side down
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    Apr 2011
    Graham, TX
    5
    Quote Originally Posted by Nightmare
    Bubble side down
    LOL....too funny. I was just about to ask!!
    Dallas TX
    186
    Throw that puppy on the pool, it'll help warm it up real quick for the swimming season!
    33k Gunite, CompuPool CPSC48 SWG, Sta-Rite System 3 DE, 2.25hp dual-speed, POOLVERGNUEGEN Pressure-side
