Results 1 to 15 of 15
Thread: Coolest pool cover ever
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    or did they use fertilizer instead of bleach
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Coolest pool cover ever
    LOL that's too funny. I bet there are alot of pool owners that haven't found TFP that want to do that...
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    With the price of groceries.........I'd plant some corn on it!
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Phosphates must be off the chart.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    What would be really cool is if that was an automatic retracting cover. Press a button and the grass goes down and then slides sideways off underground somewhere.
    Ottawa, ON, Canada
    153
    What would be even cooler is if you could simply make a hole in it and dive right through it!
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    Wow... they were nice enough to leave the ladder and the handrail.
    Now that is not covered in Pool School. Look at all that algae, so thick you can walk on it!
    The pump and the SWG must have both failed!
    And yes, I know its actually a filled pool with grass growing on the fill.
    Pool #1 IG 24k Diamond Brite plaster with spill-over spa. Jandy Aqua Link RS One Touch with built into pool floor cleaner. Jacuzzi Magnum pump/basket feeding Hayward top mount Zeosand filter. Jacuzzi Magnum pump/basket for Spa Jets. Heat Siphon pool heat pump. Dolphin Robotic pool cleaner.
    Pool #2 IG 35K 20X40 Vinyl. Hayward top mount Zeosand filter with Pentair 3 HP IntelliFlo VS+SVRS. Chemical Free pool using Water Doctor Copper Ion Generator, PoolSkim, Polaris 9300 Sport robotic pool cleaner, Heat Siphon pool heat pump, solar blanket, Ameri-Dome 50X30 dome enclosure during Winter.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Ugh, one of my co-workers has one of these. Her husband sent her out of town to visit family, and when she got back it was full of dirt! He's lucky to be alive...
    Quote Originally Posted by Melt In The Sun
    Just what I need, more grass to mow. I would rather deal with a pool then more grass any day. My back yard is low/no maintenance and a big part of that is because of the 80 by 50 foot area the pool/decking takes up.
    Apr 2011
    Somewhere on the Emerald Coast
    156
    Quote Originally Posted by iPhone
    You got that right !!!!
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    LauleaHere&There's Avatar
    Aug 2010
    Rural Moloka'i, Hawai'i
    155
    I think they should add one of these:
    12' round above ground pool. 3,500 gal. Vinyl liner. Waterway Supreme Hi-Flo 48 frame pump. 1.5 hp. SWG. Sand filter with Zeobrite.
    Thanks, members of Trouble Free Pool, for being so friendly and informative!
    mr.rongilbert's Avatar
    Apr 2011
    Houston
    20
    Gotta go mow the pool....
    [center:2iylsr0w]--> 23,250 Gallon IG Salt - Plaster - Waterway 60 Sq.Ft. DE filter -2hp Waterway Champ 120 (140gpm) - Aqua Logic - T-Cell 15 SWG - Polaris pressure pool cleaner<--[/center:2iylsr0w]
    Apr 2011
    156
    Clearly you've been watching way too many James Bond movies!!
    Casey's Avatar
    SW PA
    10,423
    I would have handed him a shovel.
