Thread: Pool vacuum
    Jul 2010
    Double Oak, TX
    44
    Pool vacuum
    I have a Lettro (now Pentair) Legend. 10 years old. Still works well.
    It has been very windy in TX and I am collecting dust/sand in the pool at record levels, especially in shallow area like steps into the pool and pool seats. Historically I sweep the sand to deep end of pool, sweep into filter, and allow the robot to [ick up[ what it can. I have been considering a pool vacuum for a couple years because this process is inefficient. I have large collections of sand in a small space, then sweep the sand to the furthest pool location with the highest volume of water. Is there a quality pool vacuum I can use for spot cleaning that will improve the efficiency of removing sand from the pool?
    Thanks
    35K gallons, StaRite S8D110 DE Filter, Pentair IntelliFlo vs3050 pump, IG gunite
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Pool vacuum
    I have a cheap vacuum head I bought at Lowes. Without a lengthy explanation of why it has to be this way, I connect the hose straight into the inlet in the strainer. Believe me, it sucks plenty hard! Getting shingle grit out of the corners is the hard part; the vacuum will pick them up no problem. And it takes a pretty good tug to get the hose adaptor out of the skimmer when it's running.
    I don't think you need to look for the Cadillac of vacuums.
