Thread: Purchased wrong size Jandy valves, can I use adapters?
    So after installing my solar panels last year, I decided it is time to replace the cheap-but-painful-to-use Home Depot water valves with Jandy units, so I can also automate the setup. Somehow I convinced myself that I had 2" plumbing, so I ordered a 2" Jandy 3-port Diverter valve (4717) and a 2" Jandy Check valve (7305). Of course, now I find out that I really have 1 1/2" plumbing (I always tell myself to measure twice, cut once ... not sure how I managed to get this so wrong).
    So the question is: Can I get away with using some sort of adapters Home Depot/Lowes might have, or should I try to sell these valves and buy new ones (really don't want to go this route)? Not sure if I have to worry about something like turbulence or anything else I can't think of
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Purchased wrong size Jandy valves, can I use adapters?
    You can use bushings/adapters, but some of those valves work as 1.5" and 2" valves. For 1.5", the pipe goes inside the valve fitting. For 2" the valve fitting goes inside the pipe. YMMV, but check before you spend any money or glue anything.
    These are the bigger 2"-2 1/2" valves, so I don't think I'll be that lucky (even with the pipe inside, I still have 1/4" clearance all around).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Yes.
    You can always use bigger valves with no problems; just don't use a 1½" valve with 2" pipe!
    Excellent, thanks for confirming!
