Thread: Vacuume to waste with Intex cartridge pump?
    comawhite12's Avatar
    Jun 2010
    South Texas
    56
    Sorry if this has been covered. I searched a few times and could not locate any information on this subject.
    I am wondering if there are any tips on using this pump and filter combo to also vacuume to waste? I have a HUGE amount of fine dirt all over the bottom of my pool from all the high winds and drought here in south Texas. I have run Diver Dave a few times, but I can actually see a cloud of fine silt coming out of the return from time to time.
    I am wondering if I can pull the cartridge out, disconnect the return hose, and vacuume to waste this way.
    The pump should still function.......right?
    Thanks.
    15' Intex frame set
    4600 Gallon
    2650gph Intex Sand Filter
    NightLighter 35W
    Red Neck fountain
    Re: Vacuume to waste with Intex cartridge pump?
    Yes that should work. Remember to block the skimmer with something.
    Jun 2010
    South Texas
    56
    I have the over the wall skimmer. My hose will be connected to that inlet. I will shut off the valve where the return hose connects to the pool. That should do it I hope.
    Sand is the worst!
    Thanks
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
