Thread: pool movement??
    Jul 2010
    Montreal, Canada
    49
    pool movement??
    Hi All,
    This will be my first pool opening,
    I notice the part of my pool has raised about an inch and a half, I think this is do to the ground freezing an now thawing, also when looking at 2 of the pool posts I can see that they are slight tillting inward, as if the pool was caving in on itself, but this again is only a little, to top of the post has moved inwards about an inch.
    I'm thinking as the groud thaws, it will go back to normal hopefully
    should I be worried, have any of you seen this before
    btw I live in montreal, canada
    Thanks
    18 feet AGP
    SWG
    Catridge
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: pool movement??
    Hi there!
    Is this a hard side AGP or a soft sided seasonal AGP?
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Jul 2010
    Montreal, Canada
    49
    Re: pool movement??
    It's a hard side I believe
    it's not a intex if thats what you mean
    18 feet AGP
    SWG
    Catridge
    crookm11's Avatar
    Jun 2010
    422
    Re: pool movement??
    As you can see I have an Intex pool and I know how to adjust the pool to remain level. I will let the experts chime in about the hard sided AGP. Mayby one of these years I will have a hard sided AGP.
    Mark Crook
    Jul 2010
    Montreal, Canada
    49
    Re: pool movement??
    Ok, so now that the ground has completetly thawed, my pool is back to being leveled, however I do still notice that 2 support post lean inward slightly, about one inch (at the top), should I be concerned at all?
    18 feet AGP
    SWG
    Catridge
    Re: pool movement??
    That shouldn't be a problem.
