Thread: Pool Does Not Get Enough Sun
    Marcm15's Avatar
    Jul 2010
    Orange County, NY
    41
    We installed our pool last year. We were / are unable to remove enough trees to provide adequate sunlight to heat the pool. The best we did was about 72 degrees except during the week of 100+ degree days, then we reached 80 but on average we were seeing about 68 or 69 degrees. I would ideally like to see the temp at 79 or 80 consistently however, the pool only gets direct sunlight from about 11am - 4:30pm.
    What is the best alternative heat method? Solar may be difficult due to the lack of sunlight, but I might be able to set panels someplace where they will get more time in the sun but will I get the added temps I am looking for? How far is my pump able to move water? To get the most sun the panels would have to be located quite a distance from the pool.
    All suggestions will be appreciated. I am very handy when it comes to plumbing / electrical so if there is a way of building something I am willing to try.
    ~21 ft Round
    ~52 inches high
    ~11,500 Gallons
    ~Hayward EC50 DE Filter and a 1hp pump. Flow Rate of 50 GPM
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool Does Not Get Enough Sun
    Adding a solar blanket would be the first step regardless of what else you may try. It will save you 5 or 6 degrees every night, which will allow it to get quite a bit warmer than it would without the blanket.
    11-4:30 is the most intense solar heating time, so some panels would certainly help if you have the space.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    I would suggest looking in to solar panels to heat the water. The panela can be mounted on roofs that have direct sunlight all day. I don't have any yet but plan on adding them to my pool. Their are many people here that use them and love them. Someone should be around to give better details.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Marcm...feel free to PM me neighbor. I have about the same situation in Dutchess cty as you do accross the river. Our pool is 30-40 ft away from 80+ft tall trees and lose the sun after 3:30 (mid-summer). Without the solar cover and two panels, low 70's is best we can hope for. I laid 2 4x20 solar bear panels, next to the pool and use a solar cover every night...80+ is not a problem. We went away for 5 days mid-jul and I left the panel valve open by accident , when we got back, I couldn't wait to jump in because it was so darn hot out (95deg...I know not bad by southern standards )...to my surprise, I felt like I hopped inot a bowl of 92deg soup...yup, the water hit 92
    Anyhow, my advice is 2 panels and a solar cover...check craigslist too!
    The below pic shows only one panel, but I've since added a second. The panels itself get sun from about 10am-3pm and are good for a 4-6 deg rise in temp per day. Retain that heat with a solar cover and you'll be in business
    Marcm15's Avatar
    Jul 2010
    Orange County, NY
    41
    Thanks for the really fast replies. It looks like Solar Panels and a Solar cover are the way to go. I will plan for that and see what happens.
    Thanks again for the replies.
    ~21 ft Round
    ~52 inches high
    ~11,500 Gallons
