Thread: The Liquidator
    Apr 2011
    South Point, Ohio
    32
    The Liquidator
    I just purchased an 8 gallon Liquidator with the upgrade and was wondering if someone could tell me the physical dimensions of the liquidator itself. It wont be here for a few days, but i want to have a spot ready and waiting for it.
    24' Round Above Ground
    15,000 Gallons
    Hayward Pro Series 100 Lbs Sand Filter
    Hayward Power Flo LX 1hp Pump
    8 gallon Liquidator 3/8
    BBB Method
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: The Liquidator
    It's tapered a little I believe. The lid is maybe 16" or 18" square and the base might be very slightly smaller. About 3ft tall.
    Apr 2011
    South Point, Ohio
    32
    Re: The Liquidator
    WOW that question was posted for a whole 7 min before it got a response.. Thank you very much for the quick answer.
    15,000 Gallons
    BBB Method
    SW Indiana
    9,198
    Re: The Liquidator
    Quote Originally Posted by mrnick0483
    Believe it or not, I almost didn't answer because I figured somebody else would get to it first.
    Jan 2011
    Riverside, CA
    352
    Re: The Liquidator
    The lid is just under 15" x15", tapers down to something less than that at the bottom. Height is just under 29"
    Leave some room on two opposite sides for the tubing.
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
