Results 1 to 10 of 10
Thread: Pentair EasyTouch - GFCI outlet
    Hello,
    I noticed that on the EasyTouch box ( metal) there is a GFCI knockout (see attached extract from installation manual). However, I am not sure what box to use on it because of the bolt pattern. Is this a Pentair part or a part that you can only find at pool stores. Home Depot carries only boxes that install on stucco...
    It would help to see some pictures as well
    Lee
    Attached Files Attached Files
    34,000 gal Pool & Spa combination, IntelliFlo 3050 (4 x 160) pump
    ET4 + IC40, Sta-rite heater, Hayward cartridge filter
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: Pentair EasyTouch - GFCI outlet
    Welcome to TFP!
    I'm no expert but, looking at the picture it looks like an actual GFCI outlet mounts to the knockout. Not an added box. It has the same screw pattern as the outlet itself. Just a thought.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Mod Squad JohnT's Avatar
    SW Indiana
    9,171
    Quote Originally Posted by crookm11
    Welcome to TFP!
    That's how it looks to me as well.
    22,475
    Mark & John are correct. All you need is a gfci receptacle and a weather proof cover. It'll screw right to the side of the enclosure.
    Dec 2009
    Central Massachusetts
    2,690
    Everybody is correct. Just screw in the plug and wire up the outlet to one of the breakers.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Yup. Standard 'Decora' layout. A GFCI will mount directly to it. You'll need an "in use" outdoor cover as well.
    Thanks everyone!
    I assumed you'd need an actual box to hold the outlet because of the knockouts ( receptacle and screw wholes). I guess I will have to use metal screws to attach the outlet to the metal body. Please confirm.
    Thanks again.
    Lee
    22,475
    The receptacle and cover will come with the screws you need to mount them.
    Mar 2011
    441
    Make sure to buy some nuts to mount the outlets. The hole in the pentair isnt threaded.
    20X40 30,000 gallon gunite pool
    Racket was correct: additional mounting screws were needed. However, I ended up using self threading metal screws . Actually 2 screws were enough to hold the outlet and the protective cover!
    Thanks everyone for taking the time to respond!
    Lee
