Thread: Pentair Diagnostic Wand Results
    susa's Avatar
    Oct 2010
    Deep South
    578
    a little high on the salt, summer rains are here so it should naturally decrease
    susa's Avatar
    Oct 2010
    Deep South
    578
    Re: Pentair Diagnostic Wand Results
    3 days later, salt level is little higher, likely due to MA injections by Simpool to keep pH at 7.6
    Two separate tests at Leslie's came out to 3800 ppm
    4/22/2011 10:55:01 AM
    SYSTEM STATUS IC40 SERIAL 197025
    FIRMWARE IC40-2.01 MFG DATE 121509
    TOTAL CELL HRS 00067 PCB 094701202
    HRS EACH OUTPUT
    20% 00065:56 80% 00000:00
    40% 00001:36 100% 00000:00
    60% 00000:01 BOOST 00000:00
    REVERSE CYCLE 5 HRS # REVERSES 0001
    SALT 4350ppm CALIBRATED
    WATER TEMP 86
    CELL VOLTS 18.2
    HRS HI SALT 00001:43 HRS LOW TEMP 00000:00
    HRS GOOD SALT 00065:50 HRS INSPT CELL 00000:00
    HRS ADD SALT 00000:00 HRS NO FLOW 00037:57
    HRS LOW SALT 00035:22
    SELF TEST PASSED
    susa's Avatar
    Oct 2010
    Deep South
    578
    rain has helped to bring down salt by 150 ppm
    4/26/2011 10:39:07 AM
    TOTAL CELL HRS 00073 PCB 094701202
    HRS EACH OUTPUT
    20% 00072:14 80% 00000:00
    SALT 4200ppm CALIBRATED
    WATER TEMP 82
    CELL VOLTS 18.2
    HRS HI SALT 00002:19 HRS LOW TEMP 00000:00
    HRS GOOD SALT 00071:32 HRS INSPT CELL 00000:00
    HRS ADD SALT 00000:00 HRS NO FLOW 00037:59
    SELF TEST PASSED
    Feb 2011
    Petaluma, Ca
    665
    Its been a while but I'm interested in where you get the printout of your swg data?
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    susa's Avatar
    Oct 2010
    Deep South
    578
    The output comes on the device display connected via USB that runs IntelliSoft.exe
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Have had that wand for years. Haven't really found a use for it.
    You need to wand a unit if it is failing or giving a red light, yes? I mean, you could wand a working unit for fun, but it makes no money, and uses up time you can't charge for.
    So you're asking a failing unit to give you a report. I wonder if the reporting is accurate? or if it is false since the unit itself is failing.
    For example how do i interpret susas' readout?
    HRS EACH OUTPUT
    WATER TEMP 82
    CELL VOLTS 18.2
    SELF TEST PASSED
    _______________________________
    This unit probably has no problems, but to view the report, could suggest otherwise.
    Total hrs reported: 73
    Hrs good NaCl: 71 +/-
    Hrs low NaCl: 35 +/-
    Hrs high NaCl: 2 +/-
    Total hrs: 108
    Hmmm.
    OK
    One 5 hour reverse cycle on 73 hours of cell time? The amount of total reverse time compared to total cell time indicates a low run percent on the cell, but a single five hour reverse cycle indicates a high percent cell run time, however, the total time, which most of it is low %, does not support this.
    Not to mention, getting your laptop out, wait for it to boot, find a place to set your laptop without it falling (off the heater that's running) Where you can see the screen good, just to get info that you may or may not be able to trust.
    I don't know... I think i get more use out of my firmware flasher than my wand.
    Factory Warranty Station for:
