Results 1 to 9 of 9
Thread: Leak In Auto Water Level "Bowl" - HELP, PLEASE!!!
    Apr 2011
    Tempe, Arizona
    27
    Recently, I purchased a new home in AZ with a relatively large, inground, pebbletec pool that sat empty for 5 months. After filling it, I immediately realized I was losing almost 2" of water every day and obviously had a leak. A contacted a pool repair company and it sent a technician to my home who analyzed my pool by using the dye test and allegedly found a leak in one of the two skimmers. He then plugged the opening that's connected to my auto-water "bowl" and allegedly found a second leak by removing all the water in the "bowl" using a cup and sponge. When he showed me how the bowl was slowing filling up even though it was plugged, I was sold on his analysis; but as he continued to wipe up the water, the water seemed to stop filling up the "bowl." Regardless, I knew I had a leak and trusted this company's analysis so I agreed to allow them to return to fix the leaks with an epoxy solution. Before the technician left my home he said, "I'll leave the opening that allows water to flow from your auto-water filler bowl to your pool plugged because it might be a few days before we can return to your property, and this way you'll save some $ on your water bill and potential damage underneath your patio." Over the next 4 days I stopped losing water, aside from regular evaporation.
    The day for repaired arrived and a different technician visited my home and proceeded to inform me that the leak was not in the skimmer and verified it's in the auto-water level "bowl." He then went on to state that the entire "bowl" needed replaced, to the tune of $850.00 as compared to the originally quoted $125.00. Needless to say I asked him to leave my property because I was not going to pay $850.00. He left but did not retrieve the prior technician's plug.
    I've continued to mark the water line in my pool over the past two weeks and am not losing any water aside from what is considered related to evaporation. I plan on purchasing some A+B Epoxy to fix the leak. The inside of the auto-water filler bowl is concrete so I have a few questions:
    1. Is a leak in this area common?
    2. Will A+B Epoxy work well on concrete?
    3. Any preparatory work I should do in the bowl prior to applying the epoxy?
    Thank you so much for any insight you're able to provide me. This situation has been nothing short of a nightmare.
    6000 gal vinyl 10'x20', Inground, SWG Auqua pure 700, Cartrige filter Jandy cl340, Jandy 1.0 HP PUMP
    Shreveport, La.
    Mar 2011
    Scottsdale, AZ
    406
    Re: Leak In Auto Water Level "Bowl" - HELP, PLEASE!!!
    The real question is:
    Is the concrete water crock cracked?
    Or is the pipe from the pool to the crock broken?
    My guess would be the later as these crocks rarely crack.
    Apr 2011
    Tempe, Arizona
    27
    Great question. How would one check for a leak in the pipe from the pool to the "crock?"
    Shreveport, La.
    Apr 2011
    Tempe, Arizona
    27
    If I remove the plug and the leak is somewhere within the piping from the crock to the pool, wouldn't the crock remain empty, theoretically speaking?
    Shreveport, La.
    Mar 2011
    441
    Quote Originally Posted by asusundevils23
    Leave the plug in on the pool side, fill it with a bucket, or hose and watch it go down.
    20X40 30,000 gallon gunite pool
    Apr 2011
    Tempe, Arizona
    27
    Sometimes the most obvious solution is.....well....obvious.
    Shreveport, La.
    Apr 2011
    Tempe, Arizona
    27
    I filled the crock/bowl with water and the leak was confirmed. The water appears to be leaking in a crack along the base of the crock/bowl. I'm wondering if the A+B Epoxy putty I'm contemplating using is the right solution. Perhaps a liquid plastic or epoxy might be a better solution due to the surface area and shape.
    Ideas? Suggestions?
    Shreveport, La.
    22,553
    Can you post a picture of the bowl?
    I think the epoxy will work. According to their website it'll fix everything from the break of day to the crack of dawn!
    Mar 2011
    Scottsdale, AZ
    406
    Assuming you do have a "concrete" water crock.
    If the crack is in the bottom you can mix up some "hydraulic cement", and pour a thin layer in.
    H Depot carries "leak stopper". Just follow the directions, and make sure the surface is very clean.
    If it is made out of a plastic then find an epoxy, there are many you can use.
