Results 1 to 13 of 13
Thread: Impeller Plugging all the time
    Hi all,
    I installed a new Hayward Tristar 4 or 5 months ago - in ground pool. The problem is that debris gets past the suction strainer somehow and clogs up the impeller. It clogs with green leaves, like from ligustrum or crepe myrtle, that don't seem like they should be able to get through the strainer. The last time it plugged with grass and small twigs. Of course, it is easy to clean (relatively speaking), but still a pain.
    I never had this problem with my old Pentair Challenger.
    Is the design of the impeller that much more sensitive to debris? Has anyone else had the problem and solved the problem?
    I would appreciate any insight.
    mmk
    24 ft all aluminum Esther Williams AGP, 1hp hayward powerflow 2 speed,hayward permaflex 40 DE filter, Rheem raypack 206 natural gas heater, polaris 165, hayward goldline aquatrol SWCG, main drain system.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Impeller Plugging all the time
    Does this occur when you are vacuuming or when you only have the pump on? Are the strainer baskets in place for the skimmer and the pump? What horse power is your current pump?
    Love TFP? Become a
    TFP Supporter!
    30,421
    Welcome to the forum Debris that large should never get to the impeller. Are the baskets in the skimmers? Is the pump strainer basket installed?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Was the Challenger a larger HP pump?
    As a general rule, larger HP pumps tend to have wider impeller vanes which allow more debris through.
    Mark
    Are you making sure that the basket is fully seated? If the hole does not line up with the intake, then there could be debris that gets by.
    Support the site
    Mar 2011
    441
    Quote Originally Posted by mas985
    This is one of the nice things about the intelliflo pumps nice wide vanes. We have a lot of fir needles here, which is a bear for smaller pumps.
    20X40 30,000 gallon gunite pool
    Mar 2009
    Huntsville, AL
    156
    Skimmer socks are good at catching leaves and smaller debris, but you do have to check them regularly.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    22,549
    I have noticed a time or two that once the skimmer basket gets full a leaf or two will work their way around the side of the basket. I have never had any leaves bypass the pump basket.
    30,421
    Nor have I.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Larger leaves tend to get caught by the basket but if they are water logged, then they can break up and get forced through the basket. Also, seeds, twigs, worms, small flowers, etc seem to get by the basket. Usually it is the long a skinning stuff that makes it through the basket but can easily get caught in the impeller such as pine needles as Racket suggested.
    Mark
    Aug 2007
    near the swamp
    806
    You sure there's no cracks in the baskets?
    Thanks for all your replys. The pump suction basket is correctly installed and seated. The skimmer baskets as well. No cracks in any of them.
    Yes, the new pump is a high efficiency pump with less horsepower - I don't have the details right now.
    I do believe that once the skimmer basket gets full, leaves or twigs get past the skimmer baskets and make their way to the pump, as well as stuff from the drain at the bottom of the pool. It could be that water logged leaves and small twigs get past the pump strainer. When I pull out the pump strainer, there are small twigs and plant matter (shredded leaves, grass, etc.) poking through the pump strainer holes, which is what I find in the impeller.
    I suspect it is as suggested, that the new high efficiency pump is just more prone to trapping debris in the impeller. I think socks for the skimmer strainers might help, but will probably not be sufficient. Has anyone used sock in the pump strainer? Are there pump strainers with a finer hole size?
    MMKeaton
    22,549
    If particles small enough to go through the strainer basket are plugging the impeller, then there's a serious design flaw there. I'd try using a knee high stocking in the strainer.
