Results 1 to 9 of 9
Thread: pressure drop
    pressure drop
    Cleaned the filter about 2 weeks ago and the pressure reading was perfect 9. Right where it usually is.
    The past 2 days it has dropped to about 6 even as I increased the flow rate from 1800 rpm to 1900.
    Should I worry?
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    Re: pressure drop
    That usually indicates some kind of minimal blockage on the suction side, perhaps leaves or debris either in the skimmer or in the pump strainer basket, normally very easy to fix.
    Re: pressure drop
    No leaves in either basket. Re-lubed the seal on the pump. The water flow on the eyelets is strong & the suction side pool sweep is moving well.
    Jan 2011
    153
    Re: pressure drop
    It's more then likely a clogged impeller..
    Re: pressure drop
    whats an impeller. Is it part of the pump?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: pressure drop
    The impeller is in the wet end (water part) of the pump and is what actually pumps the water. With the pump turned off, if you remove the pump basket and reach in at the bottom you will feel an inlet to the impeller. Sometimes you can reach in and pull out any blockage that may be there. However, sometimes you have to take apart the pump to remove the blockage but hopefully you won't have to do that.
    Have you recently been vacuuming the pool with a lot of debris?
    Mark
    Re: pressure drop
    Nope- no deep cleaning- I did reach in and there didnt seem to be anything in the impeller.
    30,431
    Re: pressure drop
    If all else appears to be operating correctly, you could change out the pressure gauge. They fail frequently but, honestly, a drop from 9 to 6 is not the way they typically fail.
    I would still suspect you have a restriction somewhere on the suction side. I wouldn't "worry" much, but I would continue to investigate 'til I discovered the cause.
    22,553
    Re: pressure drop
    Have you taken the filter apart and inspected it? If an oring or gasket has slipped out of place or a hole has developed in the grids the pressure would drop. Since you say you disassembled it a couple weeks ago something might have slipped.
