Results 1 to 7 of 7
Thread: New Intex Pool with SWG
    lovemy3azboys's Avatar
    Mar 2011
    Phoenix, Arizona
    63
    We just bought a new 18 x 52 Intex Ultra & are preparing the ground for set up right now. Before we fill I'll be ordering either a 2100 gph or 2650 gph Intex sand filter without copper, I'm hoping, and an intex SWG. I've been reading as much as I can here but would like advise from those that have an Intex SWG, Do I need to buy an expensive test kit or can I get away with a salt test strip & a smaller test kit?
    25,000 gallon plaster dive pool, Eclipse sand filter, 1 HP Centurion pump, Baracuda G3, TF-100 Test Kit
    22,553
    Re: New Intex Pool with SWG
    Tftestkits offers a TF-50 which is aimed toward the smaller pool crowd. If you already have a pH test it may be right for you.
    Personally, with an 18' pool I'd go ahead and order the TF-100 and the salt test and be done with it. That'll last you a couple of seasons and you'll have enough tests to run whenever you wish.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Quote Originally Posted by lovemy3azboys
    Hi,
    The Intex pools need to same water chemistry as the normal AGP. I would suggest you get the TF-100 just like Bama said. The cart filter that come with the Intex pumps are not up to par at keeping the water filtered correctly. A sand filter of any kind or brand would be a better choice. The 2100GPH and the 2650GPH are the same sand filter/pump combo. Normal operation is 2100GPH and has a max at 2650GPH. The SWG is the item that you shpould try and get without the copper. If you can't get one without copper you can always disconnect the copper portion of the SWG. Hope this helps.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Mar 2011
    Phoenix, Arizona
    63
    That's what I was leaning towards until I saw the cost... If I need it AND it will last more than a short time it will be a good investment. I just wasnt sure if the SWG would change my need for a better test kit.
    Mar 2011
    Phoenix, Arizona
    63
    Hi,
    [/quote]
    On Amazon I found a 2100 gph & a 2650 gph & now looking into them further I see they both have the "item model #" 56671EG. So what your saying is that these are the same pumps?
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by crookm11
    Hi,
    Yes they are the same pump. Some list the pump with the normal operating GPH (2100) and some list the pump using the MAX GPH (2650) I have this pump on my pool and it works great.
    Mark Crook
    Mar 2011
    Phoenix, Arizona
    63
    Makes perfect sense now. Thanks
