Thread: Mustard Algae - Bubbles?
    I am on day 2 of shocking my pool to rid it of Mustard Algae. Prior to that my readings were as follows:
    FC: 0
    CC: 0
    PH: 7.4
    TA: 90
    CH: 140
    CYA: 40
    I am currently maintaining shock level at 24. I woke up this morning to find bubbles forming where the water spills over from the spa. What does that mean and how do I fix that?
    ~20,000 gallon IG Plaster Pool.
    Hayward Northstar 2HP pump.
    Hayward Swim clear C4025 Cartridge Filter.
    22,551
    Re: Mustard Algae - Bubbles?
    What have you added to the pool lately?
    Do the bubbles look like foam or just bubbles?
    Organic oils from the breakdown of dead algae can sometimes cause mild foaming. This will go away as the chlorine continues to break down the oils. Various brands of algaecide will also cause foaming that goes away after about a week.
    The only thing I've added was acid to bring the PH down since it was 8.4+ when I started. Then I used powdered shock and followed up with bleach to keep the FC levels up.
    It looks like bubbles. Like you get when with blow bubbles.
    Apr 2011
    Seattle
    31
    Double check your Clorox, the "splash-less" bleach has a thickener (Cetyl betaine) that is also used elsewhere as a foaming agent. I had a somewhat similar experience in my spa and blamed the thickener.
    Unfortunately I do not know how to get rid of it, I had only opened my spa when I discovered it so I just dumped the water and stopped using my wife's laundry bleach.
    20k gallon free form plaster pool with a spill over spa, sand filter, Master Pools in floor cleaner, Jandy PDA and Jandy Lite2 natural gas heater.
