Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Can't keep FC levels up
    Feb 2011
    Central Texas
    187
    Hi All,
    New pool owner here. I have been trying to get my pool balanced for about a month now. The issue is that I can't keep FC in the pool. So, I shock, it falls to .5 - 0 in about 3 - 4 days and I shock again. For a while I was using liquid bleach to keep it in there, but really had rather use the tablet feeder (I know, I know, I am just lazy). I have the feeder pegged to 5 and am turning the pool close to 2X per day. We have had a lot of pollen lately, so it just might be the high load.
    Here are my latest tests (after shocking the pool two days prior)
    FC - 4
    CC - 0
    PH - 7.8
    TA - 110
    CH - 200
    CYA - 35
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
    30,432
    Re: Can't keep FC levels up
    good morning! You are not shocking the pool correctly. Pool School has an article that will walk you through the process......it is a process, not a one-time event.
    ONLY two things consume chlorine......sunlight (your CYA is a little low, I suggest 50ppm) and organics (algae) in your pool. I'm betting you have some algae you are not completely killing off. Shocking properly will do so.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    What is your target shock level? How long does it take for the FC to drop? Have you passed the overnight test?
    Love TFP? Become a
    TFP Supporter!
    22,553
    See my post in your other topic. I posted there before I saw this one.
    Feb 2011
    Central Texas
    187
    OK, time to do more reading...
    Feb 2011
    Central Texas
    187
    OK, went by HD and got 12 182 oz bottles of chlorox. Just dumped in 596 oz to bring it up to the recommended 14 ppm. I will wait a bit to test and monitor throughout the afternoon. I will do the overnight test tonight as well. I suspect that with all the pollen, there is a high load on the pool and this should take care of it. The oak drop is over here so hopefully this will get me to square one.
    22,553
    Don't be surprised if it doesn't. You may need to hold it at shock for a while. In fact you should go test it now to see what the FC level still is.
    When you first start shocking you should test FC as often as once an hour. The more consistantly you maintain shock level the faster it goes. If you test it now and it's stil at shock level, that's a good thing.
    30,432
    Good work!!
    I would suggest delaying the OFCLT test until probably tomorrow evening. Chances are it will take a little while to kill everything in the pool and it would probably be a little premature to assume everything has been killed by this evening.
    However, I like your optimism!!
    Feb 2011
    Central Texas
    187
    OK. Brushed to mix it good, tested and it is at 15. I will test again in an hour or so.
    Feb 2011
    Central Texas
    187
    May sound like a stupid question, but I am going to ask anyway. My kids are due home in about 1.5 hours. It is, believe it or not, 90 degrees out and they are going to want to swim. This is a no-no right?
    22,553
    Technically you can swim up to shock level for your CYA, but if you have something growing in there it's probably not a good idea.
    Feb 2011
    Central Texas
    187
    Checked at 3:15 and it was down to 11. Added another gal and a half.
    Feb 2011
    Central Texas
    187
    OK, After checking and adjusting every hour, the rate of consumption has been reduced. We had a bright sunny day today with highs in the mid 90s. I assume that some of the consumption was due to sunlight. I had to run an errand at 5:00 so left it till 8:00. Test showed that it droped ~ 1 ppm. I topped it off to 14 and will see what I have in the morning.
    Man, how does one do this if they have to work? I happened to be at home this afternoon for a scheduled carpet cleaning.
    Yes, dealing with an out-of-balance pool can be quite time consuming and aggravating. However, you are now armed with the correct test kit and knowledge to prevent further problems.
    By testing and understanding, you will be able to detect impending problems and take corrective action immediately.
    As long as you follow good procedures, you should have a Trouble Free Pool.
    Support the site
    22,553
    If you have to go to work just bump the FC a few ppm above shock just before you leave and test again as soon as you can. You may lose some ground but you'll gain it back pretty quickly.
    Of course if you don't lose any FC overnight and the CC is less than .5 ppm you're done shocking and you can just let it drift down during the day.
    Feb 2011
    Central Texas
    187
    About to check it for the night. Never had any CC present. Just can't get the tabs to keep up the FC levels. Assume it is the sun and pollen. Probably need to get the CYA up a bit more for my area. We get lots of intense sun. Thought I would let the tabs do the work, but might have to add more stabilizer to get it up.
    30,432
    Back to Pool School! You should be shocking with liquid chlorine.....not tabs.
    susa's Avatar
    Oct 2010
    Deep South
    578
    one way is by using a SWCG
    Feb 2011
    Central Texas
    187
    Read above.
  20. Back To Top    #20
    Feb 2011
    Central Texas
    187
    OK, Overnight the level dropped from 13 to 11. Going to bring it up a little over shock. We are expecting another sunny hot day, so I expect to loose FC to the sun today.
