Results 1 to 10 of 10
Thread: Pool quote: sand filter size
    Jan 2011
    Albuquerque
    72
    Hello -
    I've been quoted a Pentair 30" Tagelus sand filter for my pool build. Reading up on TFP, I know that it'd be best to have an oversized filter and wanted to make sure that this fits the bill.
    The specifics for my PB at this time:
    18x32 rectangular sport pool (3.5 - 6 - 4) with auto cover, approx. 20k gallons
    2" throughout (2 skimmers, 2 drains, 1 dedicated line, 4 returns)
    Pentair Whisperflo 1.5hp (I'm requesting a quote on a Pentair IntelliFlo)
    SWG - Pentair Intellichlor
    Heater Rheem
    Autocover
    Thanks for your help!
    Also - I've been told that it would be good to ask for unions to be installed between all the equipment for future issues (easy removal, replacement, troubleshooting) - is this generally recommended from TFP?
    Re: Pool quote: sand filter size
    I'm not against unions, but I don't find them worth the trouble/expense. PVC is easy to work with, just cut it and then glue it up again. So I reserve unions for something that gets opened up at least once a year, which isn't all that much.
    Yes that is a nice large filter.
    If you don't get an {EDIT}IntelliFlo{/EDIT}, think about getting a two speed pump.
    Feb 2011
    Cincinnati, Ohio
    106
    Jason, why do you say if you DON'T get an Intellichlor then get a 2 spd pump? I was planning on getting both.
    Will the Intelichlor not work on low speed with the WFDS4 Whisperflo?
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    Sorry, I said that wrong, if you don't get an IntelliFlo, ie don't get a variable speed pump, then get a two speed pump.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am pro-union on PVC pipe if it is run through concrete, there is only so many times you can cut and splice it over the years before you find yourself at the point where you need a jack hammer to get to bare pipe to splice.
    Ike
    Feb 2011
    Cincinnati, Ohio
    106
    So I will be fine running my IC40 on low speed then? I know the min flow is 25 gpm but wasn't sure what low speed on the 1hp wfds4 would get me. Everything will be 2".
    I don't want to buy the 2 spd pump and not be able to use low speed. Please confirm.
    Thanks.
    Exactly what happens depends somewhat on your plumbing, still a 1 HP pump on low almost always has enough flow for an IC40.
    Feb 2011
    Cincinnati, Ohio
    106
    Everything will be 2". Equip pad will be about 40 or so ft from pool deep end that has two main drains. There will be four returns and one skimmer. Quad DE 60 filter.
    does that help? Which salt system would be most likely to work on lower flow?
    You should be totally fine then.
    Jan 2011
    Albuquerque
    72
    Thanks everyone (yet again) for the answers to my questions! Have a great Monday.
