Thread: which one first?
    which one first?
    Hi People,
    i have some question. when you check the FC, pH, TA, CH, CYA, Borate, your all numbers are not standard. so which one you need to fix first? what next?
    In my opinion, i will fix CYA, CH and borate first then check it again then TA and FC after that pH. Is it ok?
    Thank
    Re: which one first?
    It kind of depends. If TA is below 50 do TA first, Then If PH is completely out of range fix that, unless FC is above 10 in which case you ignore it. Then FC, then PH, CYA, then TA, then CH, and finally borates and salt.
