Thread: CYA mixing bottle
    CYA mixing bottle
    Not sure what happened to it as I seem to have everything else, but somehow I have lost the plastic mixing bottle used to combine pool water and the CYA reagent. The directions say to add water to such and such a line and the reagent to another, etc. Then from there, I add it by drops into the vial until the black dot disappears.. I'm sure I can order a replacement, but until I do, does anyone know the actual amts of water and reagent I need to add (in ml) so I can test it quickly? Thanks.
    22,500 gal A.G., vinyl, sta rite crystal sand filter- Pentair Water Pool & Spa , Hayward Super Pump Self Priming 10" lift, BBB method
    Re: CYA mixing bottle
    You use 50 % pool water (7 ml) and 50% reagent R-0013 (7 ml) for a total of 14 ml. The amount is not important as long as it's 50/50. Taylor kit
    I think that the TF test uses 15 ml pool water and 15 ml cyanuric acid reagent.
    Support the site
    Sep 2010
    SC Lowcountry
    54
    In case you haven't found it already.
    http://tftestkits.net/CYA-Mixing-Tube-f ... 6-p26.html
    Viking Laguna 14K IG , Smart Pure SWCG, SwimClear C5520 Cartridge Filter, TriStar 1.5HP, SmartControl PLP4 controller.
    22,551
    I just use the graduated cylinders that I use for everything else. Mix equal parts R-0013 and pool sample and follow the mixing instructions if you don't have a stirrer (speedstir).
    Thanks for the replies. Added half (stabilizer) of what I thought I might need, then will test now that I have the parts ratio. However, I'm going to wait a few more days to test though...all this rain is going to mess up what had been balanced! Hate to think that we just had to fill the pool to get it started, and already have had to drain some off..with more yet to come.......
    22,551
    Rain won't affect the balance as much as you may think. You'll be fine.
