Results 1 to 9 of 9
Thread: Pipe Sizing and Return Question
    Feb 2011
    Cincinnati, Ohio
    106
    My PB usually runs all 1.5" lines. I requested 2" on mine and he said he will do it but that I will not gain anything because the eyeball returns in the pool will still be only 3/4" and thus will negate using any 2".
    I am having him put in Whisperflo WFDS 2 speed pump and Quad DE 60 filter. Therefore everything is going to be 2" except the returns I guess.
    Is he right?
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    30,432
    Re: Pipe Sizing and Return Question
    Is he right?
    No. Especially on the suction side, 2" lines are very desirable. Obviously, larger pipe reduces resistance (head) and the less resistance you have, the more effective the system.
    It's not a huge deal but your system will simply be a little better if you opt for 2" plumbing.
    What duraleigh said.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Tell him you want 1" eyeballs AND 2" pipe. Also, make sure he runs separate suction lines for each skimmer and/or main drain pair.
    Mark
    Mar 2011
    441
    Quote Originally Posted by briansturgeon
    I am having him put in Whisperflo WFDS 2 speed pump and Quad DE 60 filter. Ta
    Is he right?
    What size WDFS?
    And no he's not right. The only time builder should be running 1 1/2" on a pool these days are for water features.
    20X40 30,000 gallon gunite pool
    Quote Originally Posted by racket
    Or if you have four+ returns all run separately to the equipment pad and the pool isn't huge.
    Feb 2011
    Cincinnati, Ohio
    106
    WFDS-4 1HP
    You guys are confirming that I"m not crazy and I understand what I read on here. Thanks.
    30,432
    Sadly, I fear the truth may be we are all equally crazy which is why we make so much sense to one another!!
    Jul 2009
    London and France
    574
    that explains it!
    I would use 2 1/2" on the skimmer
