Hello all.
Posted a comment in SWCG section. This is my second post.
We're buying a house with an IGP.
It's 17K gallons, kidney shaped, outside, uncovered (no screening) with some trees around it. Located in Lakeland Florida.
Problems identified.
Has 4 brass valves one of the handles busted. (seems like an easy fix). Are the brass better/worse than the plastic ball valves?
Timer case rusted out, but timer works. Seems like I can get a replacement case inexpensively. Considering additional dogs want to do 2 - 4 hour timer blocks for the pump. (thinking of adding a SWCG)
Heat Pump inop. Has power. Thinking of eliminating. Pro/cons?
Pump sucks in air. Going to replace pump filter lid seal. Then go from there.
Has an inop pool cleaner pump. Considering a robot.
These are the problems reported in the inspection report. I think I've addressed them. Looking at getting your opinion.
Thanks.
Thanks.
