Results 1 to 13 of 13
Thread: Looking for comments Compupool CSPC36 (Good/Bad/Ugly) SOLVED
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello all. Thank you in advance for your comments.
    We've got a 17K gal pool. Looking at an 8 hour pump run time. 4 hours at night/4 hours in afternoon.
    Comments/suggestions/recommendations.
    (Got a test kit no numbers yet) Looking for SWCG recommendations. I understand this is a basic unit. Price is the major consideration. (CSPC36 can be had for less than $700)
    Bob
    Re: Looking for comments on Compupool CSPC36 (Good/Bad/Ugly)
    Welcome to TFP!
    So far I have only heard good things about the CompuPool units. However, keep in mind that they are fairly new and no one has any long term experience with them.
    I have had a Compu Pool in service for over a year now. It is a well built unit
    and has some good features. It is easy to clean and has good water flow.
    It has a internal timer for the pump or you can use a external timer.
    Has been trouble free so far. I only run it 50% setting during the summer
    with 6 hour filter time(25,000 gal pool). Makes plenty of chlorine.
    Cliffs
    Apr 2011
    Murrieta, CA
    2,360
    bump
    I installed mine 2 years ago and it's worked great. I had no issues with the install or operation of it whatsoever. I bought it on ebay since I found the best price there at the time.
    Rob
    25k, Inground, concrete, saltwater, NJ
    1.5 HP Pentair Whisperflo 2 Speed
    DE filter
    Compupool CPSC36 SWG
    Spa w/ 6 Jets overflows into pool, 2 skimmers, 1 main drain
    Apr 2011
    Murrieta, CA
    2,360
    Thanks for the info. We take possession in 2 weeks. Got some time. Looking at a more energy efficient pump also. It's in the air CSPC36 or CSPC48. 17K pool full sun, not screened central Florida
    Apr 2011
    Murrieta, CA
    2,360
    Re: Looking for comments Compupool CSPC36 (Good/Bad/Ugly) SO
    Purchased the CSPC48. So far so good. Thanks for the responses
    franke's Avatar
    May 2011
    Forest, VA
    32
    I find there customer support second to none.
    25000 gal Rectangle IG, Vinyl, SWCG -CircuPool SI45 Plus, Sand Filter, 3/4 hp Pentair pump with US motors echotech EZ variable speed motor
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Just out of curiosity, wouldn't one consider the 60k gallon unit too big for 17k gallon pool?
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Getting an oversized unit is usually much less expensive in the long run, though you are correct that a 60K unit on a 17k pool is pushing it a bit.
    Apr 2011
    Murrieta, CA
    2,360
    I've got a pump run time of about 7 hours. I'm running at about 30% output sometimes 40% or so. The difference in price between the CSPC36 and CSPC48 was $50. Time will tell.
    Apr 2011
    W.Sussex, UK
    29
    Quote Originally Posted by bobodaclown
    Are you still pleased with the CSPC36?
    New to pools...
    Approx 13,200 gallon pool - 24ft by 14ft by 4.5ft
    Larcon Filter with Durafiler Glass media (instead of sand)
    3/4hp Pump, 17k Heat pump, IG Vinyl pool, with Oase roller Solar cover
    Apr 2011
    Murrieta, CA
    2,360
    I ended up purchasing the CSPC48. So far so good. No issues. I've only had it about a month. Installed easy enough. I'm running 115V because that what the pump is running on. I'm using the pump timer to control power. It holds the time when the power shuts off. See this thread:http://www.troublefreepool.com/cpsc4...ll-t32089.html
    Hope it helps you.
